1 - 6 of 6 Posts
Hi all,
Here is a quick run down on some of our products and their prices. We have decided to run a pricing promo for the first two weeks and everything will be AT LEAST 20% off of our retail rates for RZR forum members only (please mention this for discount). Promo prices good through the end of May!
Fully functioning, full aluminum framed RZR doors:
These doors are framed from aluminum tubing to fit all the bends and lines of the RZR. Then they are TIG welded and skinned with your choice of aluminum diamond plate or mirrored stainless steel for unbelievable shine. We utilize locking stainless steel latches that open from both the inside and outside and are very solid. We also utilize oversized bullet hinges for more support and easy removal of the doors. Our doors are not just a perimeter frame and utilize a brace across the mid section as well as fully reinforced, gusseted plates in the stress areas near the hinge and latch. Fitment is excellent and installation is a breeze. All hardware is stainless steel and is supplied. These doors are not invasive to the riders and offer plenty of space, while not adding extra width to the vehicle. Anodizing and powder-coating are available. More pictures coming soon.
Promo price is only $360 shipped for diamond plate skin (+$115 for mirrored stainless steel skin)
Heavy Duty Rear Winch Mount (with or without 2" receiver):
Finally a solution for easily mounting a winch on the rear of your RZR! This is an ultra-heavy duty mount constructed of 1/4" steel. This mount is designed to work with a Polaris factory rear bumper also. This piece has been fully CAD designed and CNC cut for precision and strength. The mount pictured is housing the monster 4000lb Warn RT40! The mount is also offered with the bolt pattern for other Warn winches, the RT/XT40 uses it's own larger size! As you have probably sadly found out, Polaris left a lot on the table when they designed the rear hitch for the RZR...This mount features a real 2" receiver from 3/16" square tube (The same as a pickup hitch). This is an option and can be added the the piece for an extra $15. Another benefit of this mount is it also serves as a rear frame brace. This utilizes the factory holes in the vehicle and is a "no drill" installation.
Promo price is only $90+shipping for no hitch (+$15for hitch)
Heavy Duty Rear Hitch with 2" Receiver:
This is a very heavy duty mount featuring 1/4" plate steel construction and a real 2" receiver from 3/16" square tube. (This is the same as a pickup hitch). Another benefit of this hitch is it also serves as a huge rear frame brace. Also features a gusset underneath the receiver tube for unsurpassed strength and safety chain hooks. This piece has been fully CAD designed and CNC cut for precision and strength. Please look carefully at the competitors. You will not find a better built hitch for your RZR or RZR-S.
Promo price is only $58+shipping
Heavy Duty Rear Frame Brace:
Here is a very robust rear frame support for the RZR. These braces are quite helpful keeping the alignment of the frame and critical driveline angles when operating under severe conditions. These are CAD designed and CNC cut from heavy 3/16"plate steel for a perfect fit.
Promo price is only $20 shipped
Powder-coating in several colors is available for all products. Anodizing is also available for the doors to give you the option for a truly custom look.
We will do our best to follow up with each and every inquiry via PM or replying to threads like this one, but for fastest service, send us an email directly at [email protected] or use the Contact Us form on our website. Please let us know if you have any questions or would like to place an order. Shipping discounts are for the lower 48 only.
Discussion Starter · #4 ·
We have an updated "door" specific thread with pictures here. Let us know if you have any questions about the doors, hitches, winch mounts, or anything else you'd like to see for your RZR that you can't find.
Discussion Starter · #6 ·
Prices have been updated and are good through end of the month! We have been getting great reviews on our products so far. Please let us know if you have any questions. Thanks!
1 - 6 of 6 Posts
