Changing the springs to true dual rate is a world of difference ....probably 60 % gain the re -valving will give you the last 40% ...but you can do this when you need to rebuild the shocks . A lot more gains in suspension as compared to more power
Help
I installed the Shock Therapy Stage 4 kit in March. I installed everything according to directions. I noticed that my crossover rings were being destroyed by the upper spring. Shock Therapy sent me replacement crossover rings and new plastic spring dividers. I installed the new crossover...
Even though "industry changing" is used a lot with regard to new products, the new collaboration between Shock Therapy and Fox has come up with exactly that, an industry changing product that will be released at the Sand Sport Super Show this weekend September 13th through the 15th...
So I just wanted to share my experience about shock therapy and my less than satisfied experience. I will apologize in advance as this may be a bit lengthy. I want to start by saying I never did call them on these issues or address them with shock therapy. You only have one chance with me when I...
Thank you all for all your support in 2018. The code for 2018 was used 786 times! Thank you all so much.
The new code for 2019 is
FORUM52019
All caps
Looking forward to an amazing 2019!
