1 - 9 of 9 Posts
craigstumph
Finally a cure for the front end CLUNK on the Polaris RZR! As most people know, at full extension the shocks can make a loud clunk that feels like a hammer against the chassis. If you run aftermarket, heavier wheels and tires this clunk gets much worse. Although the shocks have extension stops internally they are tuned to the factory wheel and tire weight and can't manage any changes in the system so a front end clunk has become the new NORMAL in UTV's. Well, not any more. Our new limit strap kit stops the front end clunk instantly. Limit straps have been used in racing for decades. Trophy trucks and other big off road racing classes have considered them a must forever and so should you. Some of the benefits with our limit strap kits are:
PATENTED, billet aluminum, laser engraved, upper strap mounts
Adjustable, tight clearance clevis system allowing you to adjust the strap length perfectly
Quad layered straps for the best strength and longevity
Accurate sized holes in the strap ends to match the metric hardware in your car
No long spacers required for the lower strap mount that HITS YOUR TIRE
PATENTED, lower strap tab that has ZERO tire clearance issues
Grade 8 hardware through out the kit
Mounting system with the least leverage on the strap
Less strap stretch and longer strap life
Added life for your CVs and Axles and STOPS ALL EXTENSION CLUNKING!
PM or Order online:
https://www.proutvparts.com/search?type=product&q=shock+therapy+limit+straps
1 - 9 of 9 Posts
