1 - 11 of 11 Posts
Does anyone have all of the shock lengths from the different models is a spreadsheet?
If so could you point me to it or pm me with details?
If not please post your info so I can make one!!
50" 800 and 570
REAR OEM Polaris No: 814902001183 Mfr: Sachs/Mexico
RZR factory rear shock/spring info.
Length eye-to-eye: 12.57"/ 18.5".................6 inch stroke
Bushing: 13/32 (10mm) ID, 5/8 OD, 1 3/16 long
Spring preload (lowest setting): 220 Lbs.
Spring Rate: 170 Lbs per Inch
Spring Free Length: 13.5", 8.5 free coils, Installed Length: 12.125"
Preload adjuster range: .625"
FRONT OEM Polaris No: 814902001182 Mfr: Sachs/Mexico
RZR
Length eye-to-eye: 11,50"/ 16.25"............. 4.25 stroke
Spring Rate: 100 Lbs per Inch
Spring Free Length: 12.375", 6.5 free coils, Installed Length: 10.25"
Shortdraw Thank you!!
I am going to continue to compile this spreadsheet and hopefully get it posted as a sticky where everyone can see it!!
:D
Here's more I found on the internets..
.........................RZR "S"....RZR "XP"....Difference
Front Compressed...13.............15............2
Front Extended .....19.25.........22.75........3.5
Front Stroke .......... 6.25...........7.75.........1.5
Rear Compressed.....15.............16............1
Rear Extended....... 21.25..........23.........1.75
Rear Stroke............ 6.25.............7..........0.75
Discussion Starter #7
Awesome!! I will start getting this stuff entered so all can enjoy!! :)
1 - 11 of 11 Posts
