Ok, I havent been able to work on the RzR for about a week since I am waiting on stuff to come in. So I got to looking at it and decided I wanted to block off under the seat. I looked up a few and didnt really care for the ones I saw. I decided I could make one fairly easy. Here is what I have so far today. Just the drivers side. I am almost done mocking up passenger side, but I took a lunch break.
I plan on covering the bottom with some type of foam to reduce noise and heat and also hope to seal it some. I also will probably line the edges with a weather stripping of some sorts to help seal it. This will all be plastic. I measured the seat mounts and the seat to see what clearances I had and bought the appropriate thickness of plastic.
I plan attachinig the bottom piece with self tapping screws maybe at the ares awith the silver X's
I plan on attaching the top piece with the existing gold screws to the left, and then maybe putting in a couple of L brakets on the plastic wall I am pointing at and then bolting it to them
What do yall think? I was going to make it a solid piece all the way across, but now I am thinking maybe a two piece since you very rarely need to do anything under the passenger seat.
