1 - 2 of 2 Posts
Are the cast wheels from a RZR s the same offset as a stock RZR wheel offset and width?
I do no know about the offset, but; the S wheels are wider than the standard RZR. If you put the S rear wheels on the standard you will usually need to use a spacer so the tire does not rub the motor mount on the passanger side.
1 - 2 of 2 Posts
