1 - 5 of 5 Posts
The attached link will take you to the S&S Off-Road Website. Here you'll be able to check out the intake, exhaust, ECU, Camshafts, & Pistons we offer for the RZR & RZR S. Also you'll be able to view dyno charts. All S&S RZR products were developed on a crankshaft dyno here at S&S. After that the parts were installed in a 2008 RZR and tested on the Chassis dyno with the primary clutch locked to eliminate variance. All HP & Torque numbers posted are rear wheel numbers off a SuperFlow chassis dyno. Please note that we will not be offering the flat tappet camshaft kits, only the roller camshaft kits will be offered. These kits should be ready to ship in the next 2-3 weeks. All other product are on the shelf ready for sale. For questions or to place and order please call 1-866-244-2673
http://www.sscycle.com/admin/uploads/offroad/RZR.pdf
I would like to order 6 pistons 9.5 comp with stock bore and 2 pistons 9.5 comp with 81.5mm bore , all of them for turbo applications.
Regards
AMMAR ALDHAHERI
Do you have any dyno charts on the roller cam?
The attatched dyno run compares a stock RZR against a RZR with S&S Intake, S&S Exhaust, S&S 11.0:1 Pistons, S&S 6500 Roller Cam kit, S&S 7000 RPM ECU. These are rear wheel HP numbers with the primary clutch locked.
1 - 5 of 5 Posts
