1 - 20 of 20 Posts
Has anyone else had problems with their S&B Particle separator Mine was pulling in a lot of dust and dirt So I decided to take it apart and give it a thorough cleaning Started to wonder where all the dirt was coming from so I hooked up a shop vac to blow back into the exhaust and check for leaks. The entire outside cover is leaking.Doesn't seem to fit too well at the ends at all So that means it's pulling in dirt. Has anyone else had this problem and was there a fix for I contacted customer support at S&B I am waiting for a reply
They warrantied the scoop on mine because there was an issue with some “shrinking”. It still doesn’t seal well. I put a bead of silicone on it and it seems to be good. I won’t buy another one.
Silicone would work if I have to. Waiting for customer service to get back to me and see if maybe they have a fix. Also seems like the discharge piece has shrunk a little is that possible?
The Lone Rzr
Current: 2022 Pro XP4 Ultimate | Former: 2013 XP4 900
There's another post on this very issue. I believe it's the one @185EZ mentioned above. S&B will take care of it if it's the same issue. Good luck!
Discussion Starter · #6 ·
I've been talking to customer service they suggested a new Plenum seal, but I went to look at mine and it seems to be intact. What I did find is the Plenum is warped and curved up on both ends
As memory serves, S&B sent another poster a replacement for that very issue.
I noticed that same issue when I had to replace the motor. Some silicone seems to me to be the best remedy as the placement and lack of the screws appears to be inadequate. I did not think a new housing would make the difference needed.
Update I want to go riding.Temporary fix until S&B can figure out a fix for this. Sealed the Plenum with clear silicone I'll let it dry for 24 hours put it back on a machine and see what happens
Ya know….the S&B is just a pre filtering system right??
You could actually remove it and still ride…..many cars operate every day without it.
Just sayin’
Discussion Starter · #14 ·
Just sayin’
Yes I know but I'm here in southern Nevada and the dust is terrible I rather have some protection
Well hello there neighbor!!
I get the dust thing, I’m out of Henderson….was supposed to be riding Gold Butte this fine weekend but sadly the cough and sniffle demons are having their way with us….ugggg. No worries though, it’s only a cold!!
Just wanted to make sure y’all remember that this is a supplemental device and should never stop a guy from riding!!
See ya out on the trail!!
Discussion Starter · #16 ·
Well, talk about a small world. I am basically down the block from you. I ride out to Gold Butte all the time. Hope you feel better soon
Which Particle Separator is this you’re having issues with? The Wheel Well or the Roll Bar (referred to on S&B website as Particle Separator 2) model?
Discussion Starter · #20 ·
I heard back from S&B customer support today. There sending me a new Plenum and gasket no charge.Hopefully this corrects my problem
There definitely a top-notch company that stands behind their product
1 - 20 of 20 Posts
