anyone have one these fender well mounted particle separators on their pro r and real life feedback how it works for them ? thanks
The Pro r unit is a completely different design man ....the whole thing is a Rock solid ..I'd be more worried about the airbox on the rzr itself.They are similar but the Pro R ones dont have as much use I think. I would think whatever problems plague the Pro XP would bleed over to the Pro R, but that is just a guess and I have no data.
If it matters SB customer service is great when you do have issues. Each time they had a fan in the mail and I had it installed, process was less than 5 days from start to finish. When the fan went out on the trail SB told me to just pull the fuse in the main harness until the fan was replaced. So you can run your rig if you have to if something goes wrong. I ran mine with no fan for the last 50 miles of a ride on the trail and there was still a clean air box.
I never had a single dust/separation issue like others. I made sure the unit was sealed as well as made sure my airbox was good. If I had filtration issues I might not be a happy customer. I did just do the V2 free upgrade program and so far that has been easy. I sent the old unit back last week and waiting on the refund now.
This may not help, but this has been my experience, for the count I had three scavenge fans go out, two got shredded with debris, one had no power. On the third time I was told about the V2 so I waited on that instead of getting a fourth fan. Not 1 single filtration issues in almost 2000 miles total now. I have about 1700 miles in the Utah mounts and little Sahara SLC and the last 300 miles are Arizona desert.
