1 - 8 of 8 Posts
· Registered
Whats the best turn signals for my 2009 RZR LE? Best Kit for the Money?
I'm sure if you went and did a search you would find some more options. Here is a link though...
LED Turn Signal Kit Polaris Ranger XP HD EV RZR RZRS RZR4 Crew, Yamaha Rhino, Kawasaki Mule Teryx, Arctic Cat Prowler, any side-by-side UTV
I bought the turn signal kit from this company but I had them leave out the column mount switch. it is a good kit, easy to install. I also got the horn and lighted plate mount kit. I used a different switch that has the horn button and the rt and lt signal switch all on one.
· Registered
Hey Tom
where did you mount the switch and is it easy to use. I ordered the kit like you did, but had the turn signal swicth with the lever included. It looks a little bulky.
Thanks in advance for any advice,
Ray
I mounted my switch to the left side of the steering wheel. I took out the bolt shown below and went to a hardware (not Home Depot) and bought a longer sholder bolt and some fender washers. it works great, it tilts along with the steering wheel. I like the fact that it has the horn button and the hi lo head light switch and that it does not have the long lever.
1 - 8 of 8 Posts
