So here’s an attempt at a build thread🤣...
We got selected to build a tube chassis for a couple. They loved theone of a kind look that we gave Amber’s buggy Sprinkles and wanted a one of a kind look for their build. So one of a kind and mean looking was all the specs we have to go by lol. “One of a kind” is hard to do with a rzr just because everything is so small and compact compared to a big buggy.
They had already purchased the Skinny Pedal Fab tube chassis jig/buggy kit for us to use to build off of. The kitos Made of 3/16 plate and is cut into tons of pieces.
Plates and tabs included provide the bash plate under engine (with cutout to allow room for under trans), trans, rear radius rod framework, and all the tabs for motor mounts, gussets, a-arm tabs, front bash plate, steering rack mount, and accepts rs1 or regular turbo/1k diff. Tabs and plates are keyed so just pop em in place and weld them. For extra $ you can get the add on kit that locates upper front and rear shock mounts and trailing arm mounts. Tabs on the rear plate holds tube frame rails in place and plate keeps your angles correct. Front lower plate is bent 6* so when you bend your tube front frame rails to 6* it makes your front end geometry 💯
