I'm shopping for a set of 4 RZR to Rhino Wheel Spacer Adapters and am finding that they come in 1.5" & 1.75". I know its only a .25" difference but does it matter which one to get? Does the extra .25" make it significantly stronger?
Thanks! Exactly what I was wanting to know.no the thicker spacer will only make your tire stick out an extra .25". if anything it will be a little harder on your bearings, due to the rim not being centered on the hub now. but will you see that much more wear from 1.5" to 1.75' spacers, probably not.
