Hey guy, just checking to see if any of you guys are running a 3" lift kit with the stcok shocks turned up and the front sway bars disconnected. I am running a 3" kit off ebay that came with a sway bar disconnect. I currently have my stock shocks setting turned up about half the way. I have no scrubbing with me alon on the rzr. The only problem I have is if i load a 200lb+ passenger. I then get light scrubbing when hitting a large bump, while steering is maxed out.
I maxed out the stock shock setting and have no more rubbing, but the ride is way to stiff. I was wondering if I max out the stock shock setting then remove my front sway bars- Will the ride be smoother? or will it allow the fenders to get closer to the tires so they will actually scrub worse?
I plan to test in the next few days- But was checking to see if anyone ran into this before. Thanks
