1 - 1 of 1 Posts
I have seen the intake setup you guys make for the RZR. I just had a couple questions.
Does this kit come with a new connection to connect the intake to the throttle body? I am concerned about it slipping off like the stock one.
Also, I ride a lot in the water. Can this be snorkeled easily? I see that the actual intake is located on the bottom once the intake system is hooked up.
Either way I am assuming it still holds out more water than the stock air box.
1 - 1 of 1 Posts
