1 - 20 of 84 Posts
· Premium Member
I finally got an S machine into the shop to build a lift kit for it. I have the first one going for powder coating in the morning and will post pics when I get it back.
I have already test fitted this kit, checked everything out and like what I have come up with. Its a VERY solid kit or it wouldnt have the RDC Name attached to it. Everything is a 1/4" thick and it is an upper shock mount bracket. No holes need to be drilled anywhere, and the installation is VERY simple, no need to remove anything off the machine, not the tires, not the rear valance, just the upper shock bolts.
All that said, I will be looking for a couple people to try it out in the next few weeks after this first kit gets run through its paces. The kit was designed around the stock exhaust but the machine I have here has the Tow Brothers Racing Triple Exhaust on it so clearance checks with the stock system would be great.
· Registered
Is it a 2" kit? Will u offer different powder coat colors? Price?
· Premium Member
Yes its classified as a 2" kit, however the rear is a bit shy of 2" or we had slight binding so I was forced to back it off a little bit.
Not sure on price yet, but more than likely around the $200 range, yet the most heavy duty kit you will likely find in a 2" kit ;)
Custom colors could be possible on my first run of kits if the kit is ordered before I get them coated, HOWEVER, they dont stock an "Orange Madness" shade of orange, we have had a few people ask for that color for rad kit screens and gas caps but they wont stock that color for me :( If that was the color you were thinking about, I might be able to order a couple pounds of powder on line and supply my coaters with it for my own personal parts.
If you did want to do some testing for us, we could work out a discounted price for you ;)
· Registered
Yes I was thinking the orange. If possible could u quote me a price for black and one if u get the powder and have ur guy coat it.
Thanks
· Registered
Forgot to add also pm me with any specific testing u would like. I don't mind testing. I will tell u, I am a woods/trail rider. Rarely jump it.
· Registered
I've got a stock 2011 RZR S. PM me a price and I'll put it to the test. I do a lot of trail rides and rock climbs. I have heard some good things about your products. And am glad to see that you are doing this lift. Thanks David.
· Registered
sounds good thanks man
· Registered
Okay, I got 4 test volunteers here on this forum, i'll PM you guys some details and I will see if i can find a match for the orange madness powder for you Nick.
any luck with the powder? still want me to test it?
· I Like It Dirty!
Paul are you still looking for people to test this kit? .....(you should recognize me from mimb) I got a 2009 rzr-s a little more than a week ago and am itching to get a lift under it, currently running 31 laws and they scrub just a little when articulating the suspension in a turn. Let me know what you can do, Thanks.
· Premium Member
Discussion Starter · #18 ·
Sure, why not ;)
Parts are almost ready for powder coating, I'll look into your color tonight, sorry I was away up north trying to shoot Bullwinkle with NO success :(
· Premium Member
Discussion Starter · #19 ·
There are 2 pages here of metalic colors, if the orange madness is a metallic (I thought it was???) see if you see one that is close here and let me know, you would know better than I would ;)
Powder Coating Equipment Colors Guns Paint Systems Cost
· Registered
OK thanks man. I'll check it out at home later.
1 - 20 of 84 Posts
