I used self tapping screws and screwed to the supports under the trailer. It isn't going anywhere.How did you attach your etrack?
All our over-wheel ratchets are on the "outside" of the tire (front tires, on the front side; rear tires, the ratchet is on the back of the tire).For you Mac’s users: do you orient all the ratchets the same way? Or are the rears toward the rear. With the fender extension/mud flap my front ratchets have to be in front of the wheels.
Also, do you trailer in Park or Neutral? A friends neighbor who races says they never use Park when trailering, though I think he’s not using wheel nets.
Does Dynamix setting make any difference? Polaris wants us in Comfort mode when using straps, then double checking the mode after tightening down.
One last question: will Highway Patrol look for straps even if you’re rock solid with Mac’s tightened down?
Sure enough true, you can see how it all depends on what's easiest for your access and leverage.All ratchets on inside. Easier to get to on my trailer. I tighten them in a patern like torquing lug nuts not circular. Otherwise the car shifts a little and they loosen. I use the parking brake.
Is that a Nomad?I vote etrack
