NopeAnyone received any positive news related to the Fuel Leak stop ride/recall besides the empty note to contact your dealer?
Where did you get the info to check the tolerances?No updates that I have heard. Someone mentioned that there machine was going in for the fuel recall back on the 20th of January but have not heard an update from him. I'll try to reach out to see if it happened. I have taken mine apart to check to see if anything was out of spec and it all seems good so I have been driving mine until I build my fuel cell.
Compared it to a similar fuel line and QD detach from a 2020 model and measured the ID with calipers on the fuel line quick detach and on the male end diameter and length coming out of the fuel pump assembly and I checked on the return line assemble as well. Checked to make sure the seal on the fuel pump assembly was on right as well.Where did you get the info to check the tolerances?
Got it. Thank you!Compared it to a similar fuel line and QD detach from a 2020 model and measured the ID with calipers on the fuel line quick detach and on the male end diameter and length coming out of the fuel pump assembly and I checked on the return line assemble as well. Checked to make sure the seal on the fuel pump assembly was on right as well.
WelcomeGot it. Thank you!
Some have said Polaris is good about reimbursements with extending warranties, gift cards, accessories and stuff like like AFTER the repair has been done. I just don't have the patients to wait lol!Ive got a 2022 RZR XP Pro extreme and I got my recall notice a few months ago, then I get a notice that my warranty is about to expire. Polaris should extend the warranty as the recall is a "do not use the vehicle" recall.
You'd have better luck trying to ride a Unicorn 🤣You could go buy a Speed utv and be able to ride next season
People are finally getting them now....From the Pro R comparison yesterday. They are coming partially welded to "SPEED" things up, and they addressed the potential of ripping out the cast mounts from the case by adding birdshit weld to the bushing sleeves so the arms can rip out first. Even Polaris couldn't even screw up this bad.You'd have better luck trying to ride a Unicorn 🤣
After mine was back to the dealer 6 times in the first 3 months I called and asked them wtf and they gave me a 3 month warranty extension, because I was only able to get 35 miles on it in 3 months and 300 miles on my truck taking it back and forth to the dealer every time I started it.Some have said Polaris is good about reimbursements with extending warranties, gift cards, accessories and stuff like like AFTER the repair has been done. I just don't have the patients to wait lol!
