My 09 RZR 800 has some issues when starting. Usually, when the engine is cold, you crank the engine, and it will start, and usually cough out of the intake a couple times then die. If you restart it, it will usually run great, and have no issues. Usually just the first, cold start.
Today I noticed it did the same thing, but once it was warm, if I shut it off, it would ocassionally Cough throught he intake every once in a while at an idle. I recently took off the throttle body, and cold air intake off and cleaned them. Im not sure if this would have caused anything.
Anyhow, what can make this thing keep coughing through the throttle body? Would that be bad plugs, or? Thank you for any help you can provide!
