Thanks. That's what I was finding as well. Can't believe there isn't someone out there who has made one.I tried a lift on my 2020 and fox shocks got in the way. If you really want to lift it, it's probably better with a S conversation if you have attached shock reservoirs.
Sent from my SM-G781U1 using Tapatalk
@WSN Bigger tires and rims will give you lift on the 2021 Ultimate. Check out this thread here: 2021 Trail experience with 29sDoes ANYONE make a lift kit for a 2021 RZR 900 Trail Ultimate? All my Google searches have come back negative. Thanks in advance!
I had the same kit on my fox edition and it would hit my front shock reservoirs on full lock with any decent bump. And the rear mounts moved and dented the area around the rear mount. I ended up removing it and throwing it away.Installed this lift on my 2021 900 Trail Ultimate from Perfex yesterday.
2" Lift Kit Polaris RZR 900 50" (2015-2022)
DESCRIPTION The PERFEX 2” lift kit for Polaris RZR 900 Trail/XC is engineered to allow full drop of the suspension of your RAZOR in front and rear without causing any binding in the factory CV joint. No more hang-ups and broken skid plates. Our 2 inch kit will help you get over those spots...perfexind.com
All the parts were well made and powder coated nicely. It took a couple hours to install and the instructions were very good. Also added an inch to the preload on the rear since it sat so low. Will test it out tomorrow. I'm running 27 x 9 x 12 Terrabites on all four corners.
Before / after measurements:
Front height: 10" / 11 5/8"
Rear height: 8 3/4" / 11 1/4"
Front width: 51 3/4" / 51 3/16"
Rear width: 51 9/16" / 51 1/4"
I have a set of new factory take off 1000s front and rear a arms. Also have a set of high lifter plus 1 1/2 front and rear hi clearance arms for the same chassis.Does ANYONE make a lift kit for a 2021 RZR 900 Trail Ultimate? All my Google searches have come back negative. Thanks in advance!
I appreciate the offer but I will probably just buy a bigger machine.I have a set of new factory take off 1000s front and rear a arms. Also have a set of high lifter plus 1 1/2 front and rear hi clearance arms for the same chassis.
I completely understand. I have a Pro R on order. But I can’t give Up my 60” wide 1000S it’s just way to nimble for the tight Woods trails. 24’ trailer on the way too.I appreciate the offer but I will probably just buy a bigger machine.
I can confirm that the Streetrays 2" lift kit fits on the 2021 RZR 900 Trail. No binding on the axles (tested while up on jacks), and no noticeable difference in ride quality.Does ANYONE make a lift kit for a 2021 RZR 900 Trail Ultimate? All my Google searches have come back negative. Thanks in advance!
I used Highlifter spacers - ordered from their website. Fit without any issues.What is everyone using for spacers? I'm looking at 2" and I see lots that look the same, Orion, NC, etc. Any advise would be great. I purchased 2 sets of US made spacers for our machines and they do not fit, and now I need to pay shipping to send them back. Not really pleased at about 50 bucks.
Looking for the best at a reasonable price for a 2015 and 2018 RZR 900 trail EPS
Thanks in advance.
I had that kit on my 2020 900 trail, it is junk. 1 trip out in the dunes and the rear brackets were bending.I can confirm that the Streetrays 2" lift kit fits on the 2021 RZR 900 Trail. No binding on the axles (tested while up on jacks), and no noticeable difference in ride quality.
[SR] Front & Rear UTV 2" LIFT KIT For 15-20 Polaris RZR 900 Trail & XC 50" Model
Check out the deal on [SR] Front & Rear UTV 2" LIFT KIT For 15-20 Polaris RZR 900 Trail & XC 50" Model at StreetRays.comwww.streetrays.com
