1 - 11 of 11 Posts
was riding other day and heard my exhaust get loud my head pipe broke upon further inspection my motor mounts on the cast engine are broken how do I fix this and how much is it going to cost only have 1200 miles
Are you sure the tab broke on the engine and not the transmission? My 2008 broke the tab on the transmission that connects to the engine. Had to replace the trans housing because two professional welders wouldn't fix it.
Sent from my moto g(7) using Tapatalk
Discussion Starter · #10 ·
I can take the whole motor and rock it back and forth it's the two studs that come up into the crankcase I believe can see the aluminum is broken around them pretty sure it's the engine? thoughts?
Yup, sounds like it's the engine if it's the two studs on the bottom. If it's the two studs on the top it's the trans.
1 - 11 of 11 Posts
