1 - 16 of 16 Posts
Constructed from 1 1/4 inch chromoly steel tubing and CNC machined ¼ inch high tensile steel axle holders. Mounts using Black Max Teflon lined 15,000 lb chromoly heim rod ends that can be adjusted for an extra 2 inches in length if desired. Powdercoated for a tough long lasting finish, this kit comes complete with custom molded UHMW skid plate. This setup will put the RZR 170 broken arm issues to rest once and for all. Don't waste your money on the junk oem replacement. $493.90 retail, $473.90 for Forum Member's.
i put one on my sons RZR170 after trying to repair the stock swing arm 3x with no luck. The Factory UTV swing arm was great and so easy to install, and worked great
Discussion Starter #7
We appreciate the business. Our swingarm is definitely the answer to the junk pot-metal stocker.
I installed one over the weekend on the kids and am 2 chain links short, even with what was provided. In your original picture (on this thread) it looks like you supply 4 links. Is there any more adjustment to use the 2 links you sent, or should I just try to get 2 more? I hate to scrap the chain it is only about a month old.
Very well built product and I put the LTZ 450 shocks on also.
Discussion Starter #14
Give us a call and we'll see what's going on and what we can do for you to resolve 916-383-2730
1 - 16 of 16 Posts
