1 - 20 of 34 Posts
Works for me... Printed it out and it's going in my toy hauler
Thanks Sudnrush
Discussion Starter #6
Your welcome guys. Glad I could help I've learned a lot from this site im glad I can give back.
Sent from my SCH-I545 using Tapatalk 4
Suspect Parameter Number (SPN)
Failure Mode Indicator (FMI)
OK, I'll ask the dumb question, what do those terms mean? And where do I find them?:question:
You will get the numbers when you put your display into diagnostic mode. SPN is read out in the odometer area, and FMI is read out in the clock area of your display.
I know this is an older thread, but I just went through this myself.
Wierd part was my 2 numbers didn't match up to the same fault. Has a SPN of 520228 and a FMI of 12 which indicates 2 different issues.
So, I found the error code on the chart and have read the description. Now how do I fix the problem? I have an error code P 1691. The component is rear differential output, Condition is driver circuit open/grounded.
1 - 20 of 34 Posts
