Rub area clarification
2K views 5 replies 3 participants last post by  Stumpduster
Hey all,
So the rubbing that everyone with big tires talks about... that rubs inside the fenders or on the bottom of the fenders?
The reason I ask is that ITP makes their 14" rims with 5+3 (5" inside the hub and 3" outside of it) but they also have a set of widebody rims that are 3+5.
With the areas that you guys are rubbing, will the widebody rim help or hurt the situation??
P.S. I'm more so talking to the 26/27" tire guys with no lift/2" lift with spacers or without.
I'm just wanting to try and make it easier so I can order my tires/rims.
Thanks
SS212 with 26: bighorn rubbed the fender flares directly above the tire, only when close to bottoming out. Does not do it any more due to springs and also already have a wear pattern in the fender flares about 1/4" deep. No lift kit.
ahh, so then the widebody rims (3+5) wont help anything for that then... standard rims it is I guess.
rj, did all four hit the flares, and was the wear patterns and rubbing before the springs? I'm good with my setup, but I don't think most of these newer Rzr owners realize that the stock springs will soften after a few miles.
26" or 27"
Might want to "search" this topic some, as many have stated the fronts rub inside and they resort to heating and reshaping the firewall/floorboard. I've wonder if in those cases a wider offset or using spacers only make it worse!
I would think that the wider offset would not make it worse since its moving the tire away from the floorboard by at least 2 inches... and since the rubbing is on the bottom of the fender with a standard offset, the wide offset wouldnt help/hurt at all either.
*man I hate doing research.. it just makes me change my mind lol. I switched from 28" to 27" but now I saw a vid of a rzr with 29.5" tires and he still had quite a bit of space..... I think I'll do some dismantling and check out the 28" if I can get my local shop to lend me the tires for testing.
