1 - 7 of 7 Posts
My 2017 1000s with AA stock tune will only reach 7300 Rpm in high gear. The limiter is set higher.
I am running 30" tires with Dalton clutch kit. Clutches resently inspected and cleaned cleaned.
Should I expect more Rpm in high gear??
Discussion Starter #2
Any have any replies to this?
I don’t have the answer to why, but yes, it should reach shift phase rpm above 8000 and then basically pull all the way to rev limiter if you stay in it
Low RPM at top speed is a power related issue, I would be suspect of the tune or some other issue that popped up.
Very rare that anything clutch related causes low rpm issue at top speed
So the question is what is the last thing you changed before it went lower? If tune then that might be it
Yes...i had the same issue...call dalton. They ended up sending me a new primary spring for a sportsman highlifter 1000 (gold i believe) solved my issue
17 1kS
It is your Primary Clutch Setup. You should get to almost 8300 RPM. The S motor being more a low end motor you might be OK. Point being, you have more HP at 7300 than 8300.
1 - 7 of 7 Posts
