rough low idle when cold, can't figure it out
21K views 12 replies 3 participants last post by  204 AR
2008, 1500 miles. Stock except for the Napa muffler ala BlueToad's instructions on an old thread I found (much quieter). It's a good size muffler, don't think it's a restriction and it didn't run any different before. Also the original owner changed clutch weights, what with I don't know. It runs like a top other than the cold idle. I thought it was normal until I bought another 08, and it's smooth as silk.
Ok, so here's what I've done.
Changed fuel pump. No change. Never have checked fuel pressure, but never cuts out at high rpm and always starts great hot or cold.
Spark plugs, no change. Ohm tested wires, both the same.
Cleaned tbap, also exchanged it with the other rzr. No change. Chased the wires to the ecm and ohm tested, all 4 perfect.
Set the tps to .732 volt at idle. Actually messed with this quite a bit. It was .665 to start with iirc. Set warm idle speed to 1090, +-10. This is as fast as I can go without kicking the belt in and getting a jump when going into gear. Actually wondering if this is an issue, not sure what's going on there since the other one idles at 1230 or so.
Good battery, optima red, get 14 volts while running. Same voltage to the fuel pump as the other one, can't remember now what exactly.
Swapped ecm with the other one, no change.
Checked voltage of tps all through throttle range, goes up smooth all the way to 3.7 or so, can't remember the exact number.
I'm about out of ideas except to up the idle to 1250 range, let it cool and see what that does when cold. Then if that fixes it address whatever clutch changes I need to make. Or just go with it as is, it never dies, just sputters and starts off around 800 rpm for a bit then works it's way up. It was fine this way even in the cold all last winter. It just irks me to not be able to figure it out!
Somethings to check. The boot from the throttle body to engine. Know to came loose. Check grounds. Also check the wire connector assemble going into the ECU. Behind the drivers seat. 2008 had a problem with the weight of the harness pulling down hard and making bad connections inside the connector. Can really effect the way it runs. Seems like all of my bad running problems where corrected when I pulled apart the connector and pull wires so they had slack. Figure out a way to take the weight of the harness of the connector.
Something else for the 08 was the fuel mixture system, EFI. It had several sensors and could take several starts before the system got it's final calibration. If one dies when first started cold and has to be restarted it was the EFI system making adjustments. Might trying to restart a couple of times when running rough cold and see if it smooths out.
Thanks for the tips. Intake boot is new, upgraded to the newer style with bellows and it's tight. That ecu connector is quite the mess but I've had it off several times now, even had it open last night finding the tps wires to test. Didn't notice anything loose but didn't really check them all either.
I have not done anything with the grounds, other than verify they were solid and not loose. Might be something to try. Didn't know about the restart trick.
The wires in the connector will not be loose. The wires are pulled very tight. Carefully pull slack in them toward the little connectors. I think with the wires get so tight they pull so hard it causes a bad connection. By pulling slack in the correct direction you take the stress of the little pins. Had several bad running and missing episodes that were fixed by doing the above. That was after I did all the usually checks like you have done.
So I took the grounds loose and cleaned them up good, also got some slack in the ecu connector wires and pushed them in , no change. So far nothing has made any difference good or bad. It idles fairly nice once it's warmed up at 1090, 1100 with a bit of variance and kind of lopes along. Tomorrow I plan to take the belt off and make sure I don't have something wrong in there.
Winner! Those of you who suggested this were spot on.
Actually first I adjusted idle to 1200, tps to .741. It seemed smoother there than any lower voltage. As I figured, the secondary was spinning at that speed. I could stop it with my foot, but it made the machine lurch when I put it in gear so that's no good.
I didn't know much about clutches so spent more time educating myself. First messed with alignment, thought I had it but no dice. Tried 2 spare belts, no help. Cleaned the primary bearing with brake cleaner, freed it up even better but no help. Finally I started it with no belt, and noticed it squeezed together just a tad. Luckily had the original weights given to me when I bought the machine and changed them out. All better now, secondary is stationary at idle.
We will see how it runs cold now, but I think it will be significantly better. At the least I got one problem solved. I can about see just how it got like it was, first owner changed weights for some reason, then had to lower the idle speed. And probably didn't know enough to adjust tps, that's why it was off the first time I checked it. The second owner who I bought it from (friend of mine) just didn't know any better, since like me, he had never been around any others and it ran great other than the idle.
