1 - 20 of 35 Posts
Got the 2010 rzr4 home loaded the family in an when doing a turn i rolled it on its side. We are all fine but i will take turns slower from now on.
So i have a slight rattel in the center just under the floor but it goes away as soon as the clutch engages. It did this before the spill.
any ideas before i take it apart or bring it back to the dealer?
My 2011 does it after I let off the gas as it slows down. Same location, same rattle. I have no idea. Help on this would be much appreciated.
Glad to hear you are ok. Were you on asphalt?
Banned
Isn't that officially "Laying over"???? But if it makes you feel better;) Saw it happen to a RZR-4 on one of our rides! Still can't figure out how he did it????
The rattle you are hearing is probably just the play in the propshaft under the floor boards. It's normal. You could grease it up a little, but it won't fix it permanently.
Glad everybody was okay.
I think you need the inside warnings that i read 1million time waiting for somebody to bring the gas.
I am really wide and low for racing ....
and dont tell me they wont roll over ....
oppsss ... rzr 4 ...sorry didnt see that!!!
Discussion Starter · #14 ·
I was drifting in a slow turn on a slight hill and when the wheels got traction back it slowly rolled on to its side.
I was quite suprised because we were moving very slow.
page 17 in the manual warns of this.
i have only put my rzr on its side once but that was a std width 50". With the Svor aftermarker LT you can take turns alot faster with no problem.
Discussion Starter · #18 ·
The seatbelts worked great. I was on the high side of the roll and they held me in my seat. The nets also helped.
When I picked up my 2010-S one of the shop guys said he put his on its side and the stock belts worked about as well as the stock seat belts in a car or truck he ended up on on the passenger side, I took it as a warning.
I had ordered the CROW 5 point harness for my RZR before I had even went to pick it up so it didnt matter to me I was just curious how they worked for you, glad nobody was hurt hopefully the RZR didnt obtain too many scars then again scars are cool too.
1 - 20 of 35 Posts
