If you come across it, please let me know. I'm trying to find some info myself. Dual rates are in the plan, but just no budget for it this year.I'm seem to recall an article about that and that you could continue to adjust even tho the spring was compressed, I'll have to look for it.
Keep cranking until you have your ride height set.
Boom 👊 that's what I was looking for. Thanks gents!The top OEM spring in not a tender spring, it's just there to keep the main spring in place at full droop. You can add more preload to regain ride height. Just don't add so much preload that the main spring will go into coil bind at full compression.
So based on the info under your pic for your machine the factory preload setting (which can be found in your owners manual) is 6.35" measured from the bottom of the shock cap to the top of your preload ring. Ideally with your machine ready to ride(meaning you, passengers, fuel and whatever cargo) you should be about 13.5" of ride height in the rear with factory sized tires. (Front should be at 14") So you can increase the preload to help raise machine closer to that 13.5" ride height. As stated the upper spring is really just a tension spring. This machine does not have a true dual spring setup. Only thing to be aware of is that Polaris recommends to not exceed more then an inch over the factory setting for preload. (So don't go more then 7.35" of preload) If you can't achieve ride height with that much preload the way to correct it would be to swap out factory springs with higher springs rates to handle the higher payload. As for the ride it should actually still feel fairly close to how it was before you added the weight. Only time it will feel "stiffer" is if you take the weight back out of it and leave the preload unchanged. Hope this helps.After installing my @CageWrx tire carrier and dropping on the spare, I'm sitting about 1.5" low in back. If I have my head wrapped around this correctly, I'm maxed out on height adjustment since the tender springs are fully compressed? Thanks!
This is false. If it were true it would go against the laws of physics. You can get a stiffer ride by changing spring rate or shock valving. Obviously adjusting preload does neither of those. All preload does is adjust the ride height. If you measure the spring length with the vehicle at rest, move the preload rings an inch, and then measure again with the vehicle at rest, the spring will be the exact same length at both preload settings.After you add enough preload to regain your ride height it is going to ride a lot stiffer. Personally if your not going to do a full spring kit in the future I would add tender springs. They will regain ride height and soften the ride most of the time
That's a good point.I think the confusing word here is "preload". For the most part, nobody actually adds any "preload"... They just lower the collar to raise the shock body in reference to the spring. Meaning, if the springs do not take up the entire threading on the shock (fully extended) or you have not run out of shock travel when you move the collar, you're not doing anything with preload, you're just raising/lowering the location of the spring.
@YAMAHA, "preload" is referring to tension placed on the spring prior to the weight of the vehicle. Using my above example using a 200# spring. Say that spring uninstalled is 12" in length. You install it onto a shock and say the manufacturer states it should have .5" of preload. So in other words you compress the spring to 11.5". There is now 100# of tension on that spring before its even installed onto the machine because we have compressed it a half inch. Think of it more like "pre-tension". You are simulating a "load" placed on the spring by essentially squeezing it together using the collar and threaded shock body.
That's the thing you are wrong about. The "at rest" (vehicle weight on the suspension) spring length does not change when adding preload. If it did then yes, you would be correct it would make it ride stiffer, but it simply cannot. Preload is "pre" loading the springs, but once you actually put the weight of the vehicle on it, the amount of preload you have doesn't affect the length of the springs. I challenge you to give it a try. What you are saying makes sense in your head, because you don't really understand how it works. Measure your springs between the preload ring and opposite perch, then add some preload and measure again. Just make sure to fully settle the suspension and move the vehicle before measuring each time. The spring length remains the same, you just have more shock shaft outside the shock.. Another thing you point out is the length of the springs after increasing preload will be the same. This is false.... if say the bottom of your preload ring (where the top of the spring pushes against) and the spring cup (where the bottom of the spring sits in) are 16" apart, then your spring is compressed to a length of 16". Now, if you adjust your preload ring another inch the 2 points are now 15" apart. So there is no way your spring is still 16" because well....math.....So, to the rider the added preload will most definately be felt as a "stiffer" ride. The only way to increase ride height without changing the "feel" is to change the shock mounting positions. Either a lower upper shock mount (typically on the frame of the machine) or raising the height of the lower shock mount (typically on the A arms or trailing arms) hence what is typicly referred to as a "lift kit".
