Just installed Ride Command in 2018 XP 1000. Worked fine after installation. Went riding last weekend and it continued to work fine until about 2 hrs into the ride the display went blank. The screen was barely illuminated with white vertical bars. Checked fuse and wiring/plugs in the field - everything good. Even when ignition was off, screen was still faintly illuminated by vertical bars. Upon return home, disconnected the battery cable and the screen went black (illumination ceased). Reconnected battery cable and started RZR and GPS appears to be functioning normally. Has anyone else experienced this issue? Can't have the unit shutting-down on the trail!
Thanks,
5SFG
Thanks,
5SFG
