Is it possible to reuse it? Stealership says back order for 2 weeks.
futuredenied · Registered Joined Oct 29, 2008 · 268 Posts Discussion Starter • #1 • Sep 4, 2010 Is it possible to reuse it? Stealership says back order for 2 weeks.
GIFF-TURBO · Premium Member Joined Aug 27, 2008 · 12,793 Posts #2 • Sep 4, 2010 I have heard it can be done if your in a pinch......I have not tried it myself. Maybe try hitting it with some copper coat would help. I would try it before I waited two weeks for a new one
strracerx · Boats and ***s Joined Mar 8, 2008 · 3,184 Posts #3 • Sep 4, 2010 sure, if you want a head leak but if its absolutely neccassary, make sure the gasket is in good condition and use a can of "the right stuff"
futuredenied · Registered Joined Oct 29, 2008 · 268 Posts Discussion Starter • #4 • Sep 5, 2010 Mine was in great shape. Bolted all back together no leaks! Thanks guys. Time will tell.
Tuf-Skin · Registered Joined Apr 24, 2008 · 15,386 Posts #5 • Sep 5, 2010 Call HPD and see if they have any. They modify the stock head gasket and make the coolant passages bigger for better cooling. I have a HPD high flow gasket sitting on my shelf if you need one fast.
futuredenied · Registered Joined Oct 29, 2008 · 268 Posts Discussion Starter • #6 • Sep 5, 2010 If mine fails you"ll be my first call thanks!
futuredenied · Registered Joined Oct 29, 2008 · 268 Posts Discussion Starter • #7 • Sep 7, 2010 30+ miles no problems. thanks guys
