1 - 4 of 4 Posts
Holz Racing Remote Oil Cooler Adapter $79
This billet machined adapter was built to allow you to design and build your own oil cooler set-up as well as be able to mount it where it will benefit you the most.
Heavy engine loads and high performance applications can make your engine temps skyrocket. Adding a remote oil cooler will help address that very issue.
Kit includes everything shown in picture:
- Black anodized billet oil filter adapter with o-ring
- Stainless filter adapter nut
- Blue anodized AN6 male oil line adapters with o-rings.
You will need
- Oil cooler of your choice. We use and recommend Setrab brand coolers.
- Up to 8 or 10 feet of hose. Lines should be as short as possible so as to maintain proper oil pressure.
- Female -6 AN fittings for attaching new oil lines to adapter.
- Fresh oil and oil filter when install is complete.
In Stock!
1 - 4 of 4 Posts
