21 - 35 of 35 Posts
Keep trying different things. Wonder how spraying with teflon lube would work. Suppose to turn dry when applied.
  • Like
Reactions: rzrhle
Wonder if it would work for the rest of us non-mudders.
I apply dry lube liberally to clean shocks before each ride aswell.. it helps a bit, but I agree with greyhoundman
Discussion Starter #26
Well, I think the band-aid idea went out the window. I took 2.5” stainless exhaust pipe and expanded it with the HF press enough to give it a light press fit onto the shock body. It fits snug but ( if a can get it back off) I’m going to drill a small hole and weld a nut on it near the bottom for a set screw to ensure that it doesn’t slide off. I left plenty of room for shock adjustment and the spring divider will never get up to the threads. I would appreciate any thoughts on it- good or bad because I’m not a machinist, metal allergist or welder. I’m a biochemist 😂
659984
Nice ideal with potential. Not sure how anything protruding will survive the harsh spring travel. Spring might destroy it. How about a crip on the bottom that has to be forced on and would be smooth.
  • Like
Reactions: rzrhle
I tried something similar with central vac tube from Home Depot. The fit was very close and the slider moved perfectly. Just have to figure out a way to secure it.
Lost patience with it but might try again during the winter
Discussion Starter #31
I'm curious, how did you expand the tubing with a press?
I used a bushing/bearing driver set. The I.D. of the pipe was 60.6 mm. The O.D. of the shock body was somewhere around 63 mm. So I had to stretch the pipe roughly 3mm.
I stretched it 1mm at a time. I started with a 61mm driiver followed by the 62, 63 and 64 drivers. I found that the pipe had memory. After pressing the 64mm driver thru, the pipe I.D. was left at 63mm but that was enough to press it on the shock.
660056
Discussion Starter #32
To finish up- I drilled a hole and welded a nut on to the top back of the sleeve so to use a set screw. I had never welded on stainless steel exhaust pipe before and I learned real quick that I had to do short quick tacks letting it cool in between or I would just blow thru it. I got the nut welded on and tightened the set screw down into the threads of the shock- no way the sleeve can slide off, it would have to dig thru about three inches of shock thread to do so. There was a little bit of a clearance issue but after I tightened down the screw, I ground down the head of it so it would clear the tender spring. It’s ugly and why I put it on back - 😝
The other side still has the bandaid on it so I think I will leave it on there for a ride or two just to see how it does. In the mean time I will be making another stainless sleeve for it.
I’m about 98% confident on this Jerry Rigging . 😂
660063
Looking forward to some long term results. If this works well for you then I might do the same thing this winter.
Wouldn’t Running limit straps pose a problem with the dirt skirts ?
Why? They just cover the springs. I would think they would make it less likely for a limit strap to get tangled up in the springs.
21 - 35 of 35 Posts
