1 - 7 of 7 Posts
I bent 1 rear axle on my 900s I was wondering if I can replace 1 with an aftermarket one or do I have to replace both if I go aftermarket. And if I can replace just one what kind can I use? Thanks guys
Replacing one is OK. Replacing two is better and keep the stocker for a spare. Recommend Rhino 2.0.
What he said!
You really bent the shaft on a 900S axle? How did you do that if you don't mind me asking? Have a pic? That's somewhat rare, usually the CV gives way first, especially on a shorter axle like that, or the shaft breaks outright.
Discussion Starter #6
Having 1 rhino axle and 1 factory won’t mess anything up for weight? Very good to know so I only have to do one at a time. I’m assuming when I did a pretty good roll over. I crumbled my cage and when it hit that side the tire blew.
1 - 7 of 7 Posts
