1 - 7 of 7 Posts
Hey Guys..... I have a right rear axle seal that is leaking just a little.... not so much that is dripping on the ground..... but enough that it has left a dirty ring around the CV.....
My question is...... is the seal easily swapped out? Pryed out with a screw driver and tapped back into place with a socket?
And if the seal is not leaking that badly.... should I bother changing it out?
I'll take any advice on the issue. Thanks
King of crash!
if its lot leaving drops its normall a slight wet with dust is ok but if its leaving drops on the frame time to replace...early 08s had a bad seal the new ones are a red color and yesa their easy to change......take tire off ...remove top hub bolt and you can get the cv out no need to remove it from hub i was able to do both on mine this way tight but doable
Rear seals are a piece of cake.Takes more time to get the axle out.I wouldn't use a screwdriver,they come out very easy.
Thanks guys.... I already have the whole suspension out..... so the seal is sitting right there looking at me..... I am gonna order one up and swap it out!
King of crash!
doesnt get any easyer than that...lol look and see if yours are black or red...if black you needed to change....lol
Discussion Starter #6
mine are red..... and I don't think it is leaking that badly..... I kinda just don't want it to become an issue.... I'll call the local dealer and see if they have one in stock.
1 - 7 of 7 Posts
