1 - 20 of 73 Posts
craigstumph
RCV Ultimate CV Prop Shaft for Polaris XP1000, & RZR XP Turbo 2 & 4 Seat
RCV Performance Products 2-piece prop shaft featuring specially designed CVs at both ends. This design eliminates all vibration and carrier bearing noise with the Polaris XP1000! The RCV design using 3 CVs and an OEM style bearing, eliminates any concern of carrier bearing failure or u-joint phasing with the smooth operation of CVs.
The new RCV prop shaft is made 4130 chromoly tubing and 300M CV components that ensure strength. Prop shaft and components are completely sealed and rebuildable. A safety loop has been designed that bolts to the factory carrier bearing mount to contain the prop shaft. Custom lengths available - contact us for details, or use our Custom Axle Configuration Form!
Fitment: 2-Seat Polaris XP Turbo ('16+)
All prop shafts are made to order.
Note: Photo illustrates an XP1000 version. Turbo rear CV flange will vary.
Warranty: Backed by a 90 day Warranty against breakage to the original purchaser. Warranty does not cover the willful destruction of product. All claims are subject to review.
Fitment:
2-Seat XP 1000 ('14-'18)
2-Seat XP Turbo ('16-'18)
Shipping is about 1 week lead time.
PM, call or text for more info
https://www.proutvparts.com/collections/rcv/products/rcv-ultimate-1-piece-cv-prop-shaft-for-polaris-xp1000-rzr-xp-turbo-by-rcv
RCV Ultimate CV Prop Shaft for Polaris XP4 1000 & RZR XP4 Turbo-4 Seat
Locomike
Thanks Craig. PM inbound.
Question that may interest others......
Is the factory carrier bearing a requirement?
I have a new SuperATV carrier bearing and would like to use it (or anything) other than the PoPo POS carrier bearing.
Is the 1 week build time usually doable?
Thanks......
craigstumph
Discussion Starter #9
Thanks......
Aftermarket carrier bearings are OK. Lead time can be 1-2 weeks depending on the RCV build cycle.
1 - 20 of 73 Posts
