1 - 20 of 86 Posts
craigstumph
2019 ultra low geared Turbo S 4
Razorback Gauges help keep your belts from blowing up by showing when belt temps soar and allowing the driver time to back off the throttle before the heat damage is done.
Free shipping
Start a conversation for your best deal or order online:
3.1 Dimmable Infrared Belt Temp Gauge by Razorback Technology
The 3.1 Dimmable Edition Gauge is the latest & greatest version of our patented, thermally compensated, infrared belt temperature gauge design. This gauge allows for real-time monitoring of belt surface temperature, and features multicolor LED temperature alerts. On the anti-glare LCD screen you'll be able to easily monitor current, average, and high belt temperatures.
Our added rocker switch now allows you to dim both the LED light as well as your LCD screen. Cycle between 5 levels of brightness to suit your riding needs! You will also have the ability to switch from Fahrenheit to Celsius if needed.
Our thermally compensated infrared sensors are medical grade, and are manufactured to withstand the harsh environments found in motorsports.
Our gauges are water resistent to IP65 and IP67 on the sensor and connections.
Mount sold separately
This gauge is available with different lengths of sensor cabling (dependant on vehicle make/model), outlined here:
15 ft. sensor cable: Can-Am X3 Max, Polaris RZR 4, Arctic Cat/Textron Offroad Wildcat (4dr.)
12 ft. sensor cable: Can-Am X3, Polaris RZR, Arctic Cat/Textron Offroad Wildcat (2dr.)Can-Am Maverick/Commander (4dr.), Polaris RS1, Kawasaki Teryx
5 ft. sensor cable: Can-Am Maverick/Commander (2dr.), All ATVs and Snowmobiles
Product Features
  • NEW Dimmable Feature- Rocker switch will dim both LCD screen and LED indicator light
  • LCD Screen - Easy to see, even when the sun is bearing down overhead.
  • LED Alerts - The incorporated LED has been programmed to change colors as your belt reaches certain temperatures. Default settings are Green at less than 200 F. Yellow at 200 F. Red at 225 F. Red Strobe at 245 F. Fast Red Strobe at greater than 260 F. For maximum belt life, try to avoid temperatures in excess of 200-225 F.
  • Machined from steel and aluminum. Not plastic.
  • Water protection: IP65 Gauge. IP67 Sensor and Connections.
  • Quick-Release Sensor
659670
659671
craigstumph
Discussion Starter · #4 ·
I just got this from you last week. Cheapest price on it around! Have a question tho as the info isn’t in the manual. The blower motor wiring that’s in the harness I’m assuming it kicks a blower motor on at a certain temp?
There are no control features on the Razorback gauges.
1 - 20 of 86 Posts
