I have a 2017 1000s and wanting to put a tablet mount in, I have seen the RAM mounting system that hook on the passenger grab handle. Could you all please put some pics up of tablet mounts with that mount and best Samsung tablet to use🇺🇲
Slick!This is my setup. Ipad mini in waterproof case. Magnets on the back to mount onto the dash to easily remove.
View attachment 701410 View attachment 701408 View attachment 701409 View attachment 701410
I too have a 2017. Love Ram products. Super solid . Thats not a Samsung in the pic, but I now have a Samsung in that same mount.I have a 2017 1000s and wanting to put a tablet mount in, I have seen the RAM mounting system that hook on the passenger grab handle. Could you all please put some pics up of tablet mounts with that mount and best Samsung tablet to use🇺🇲
Looks pretty solid, report back with your results.This is what I came up with, going out this weekend for the test🇺🇲 View attachment 701535 View attachment 701537
The setup I have a pic of with the Ram ball, I rode for 8 hours Saturday and it didn't move an inch. Trail and rock crawling if that helps🇺🇲Anyone have any tips/tricks for keeping the tablet/Garmin from vibrating downwards? The issue I found is with the ball connection on the back of the Garmin. If I ride aggressively through the woops, it slowly bounces downwards.
What size ball are you using?Anyone have any tips/tricks for keeping the tablet/Garmin from vibrating downwards? The issue I found is with the ball connection on the back of the Garmin. If I ride aggressively through the woops, it slowly bounces downwards.
B size. 25MM/1inchWhat size ball are you using?
That’s probably the issue, I run the C size and mine doesn’t move. Ram recommends the B size for phones and cameras.B size. 25MM/1inch
Originally I was thinking the same, but the movement I'm referring to is the ball connection directly on the back of the Garmin. It's not any of the connections with the RAM mounts. I wouldn't think that would matter, but I could be wrongThat’s probably the issue, I run the C size and mine doesn’t move. Ram recommends the B size for phones and cameras.
I’m using their x grip holder with a c ball mounted to the back of that and it attaches to the arm coming off my grab handle. Don’t have have pics though. You have any pics of your setup?Originally I was thinking the same, but the movement I'm referring to is the ball connection directly on the back of the Garmin. It's not any of the connections with the RAM mounts. I wouldn't think that would matter, but I could be wrong![]()
I keep forgetting to take pictures. I went on a ride again this weekend and I actually think you guys might be right so I'm going to try the next size up and see how it does. I think it'll result in the same, so I'm also going to find a different way to attack the Garmin to the mount setup instead of using the ball.I’m using their x grip holder with a c ball mounted to the back of that and it attaches to the arm coming off my grab handle. Don’t have have pics though. You have any pics of your setup?
