1 - 6 of 6 Posts
Hey guys, I have a quick question. I bought a particle separator last year and finally got it installed on my 900. It works great. I noticed that the fan turns on and off intermittently during a ride. I only notice it when I am going slow or stopped.
Is this intentional and working properly or might I have a short in the power feed?
Thanks,
Wally
Intermittently turning itself on/off is not normal that I'm aware of. Sounds like a wiring issue.
Mine runs all the time.
Yes should run all the time when the ignition is on. Did you follow instructions and use their plug adaptors for the tail lights? If all wired correctly could be a faulty connection, lose ground or power feed.
Thanks guys! I kinda thought that was the way it should work. I'll check the wiring and trace it down.
WALLY
Confirmed - it was a bad crimp on the ground. Easy fix, and the fan runs consistently now. THANKS!
Wally
Discussion Starter #6
duplicate.
1 - 6 of 6 Posts
