1 - 5 of 5 Posts
The wifes bearings are gone on her rzr where the driveshaft enters the front diff. I cant seem to find how to order just those parts so a new diff it will be. My problem is we are going to mud nats in a few days and I need to make this thing rideable, Im thinking pull the driveshaft and let her ride in 2wd.
How do I do this?
Do I just punch out the front u joint then pull the shafts out?
Please help asap
Just punch roll pin out. Pull diff and shaft, replace diff and axles so wheels stay on.
U can order just the new bearings and any bearing store should have in stock
Popo only sells pinion and bearings as one, stupid but it is what it is.
If u search or look in the ultimate front diff thread in the drivetrain section I think, u will find part numbers.
Ps it's a sticky!
Discussion Starter · #4 ·
Ive read alot of that thread but get lost in it. So ur saying I gotta pull both axles and the front diff to be able to get the driveshaft out?
You may be able to just loosen diff and move forward enough to pull shaft but not sure never had to just remove shaft! Give it a whirl. Never know till u try!
Look for the skf 61009 numbers in that thread two different numbers need one of each.
I would copy and paste but my phone don't do that.
1 - 5 of 5 Posts
