1 - 8 of 8 Posts
Ordered myself a set, received and went to install today. On the driver (left) side, do you guys have an OEM bolt or pushpin in this spot? I have nothing and it's just hanging...
645242
On the right side (passenger?) do your plastic pins stay in place? Mine pop out with the slightest breeze...
645243
Thoughts?
I assume that is on a RS1? idk how they are I know on my xp1k it has a screw there. You can always just get some velcro and put there.
Old Dirt Bike Rider
Thoughts?
Upper left, I probably added a pin for that one. Right side I probably used a new pin. My bags have been great for ~500 rough miles of SoCal desert so far. Buy some spare pins at RMATV for cheap.
I added the upper door inserts and it came with a bolt for the drivers side door where you need one. I don't remember if there was a factory bolt there. On passenger side it didn't have a hole in the PRP bag in the upper corner but it looks like I need to add one. It would make zipping the bag much easier. The lower push pin has held up great so far.
Discussion Starter #7
FWIW several of the holes in my PRPs weren't fully punched, meaning there's a cut there, but the circle of material was still in place making it look like nothing was there upon quick glance. However I knew they had to be there, looked closer and started pushing the material and out popped the circle/material. I would bet you're in the same boat.
Oh and update: For my missing left bag bolt/pin, actually found a loose bolt under my seat that matched the rest. It looked stripped toward the tip and I bet the builders grabbed a new one, dropped this one and forgot it. Found a suitable nut in my stash, worked the threads a hair so the bolt would grab the nut and problem solved. Thanks for the help!
On my 19 highlifter, I have the PRP bags and there was a bolt there
1 - 8 of 8 Posts
