1 - 6 of 6 Posts
Has anyone had the same problem?
I have a 2019 rzr xp 4 1000 and I have been getting this code, after a while the rzr won´t accelerate at low rpm´s and then sometimes just stops and turns off, after turning it on again i have to give it more gas so the rpm´s are higher and continue but with the same issue and the engine light on the dashboard turned on, if I stop for about half an hour then something cools off and can continue.
Anyone knows or have had this problem?
Thanks in advance.
2014 XP4 1000, tons of mods
Thanks in advance.
I would check or replace your fuel pump P1170 is Lean condition not rich
520344 15 Adaptive Fuel Correction Valid but above normal -
Too Rich P0170 17 Valid but below normal -
Too Lean P1170
What you are describing is classic fuel pump failure
Ok, than you all vey much for your help, i will replace the fuel pump and hopefully get rid of that failure.
Discussion Starter #6
I think i solved the problem just by changing the filter that goes on the bottom of the fuel pump assembly, I took the rzr for a drive for more than an hour and had no problem, was able to go 70mph @8500rpm's and probably could of gonne a little faster but runned out of space.
Here are the pics of the old and new filters.
660340
1 - 6 of 6 Posts
