1 - 20 of 57 Posts
craigstumph
PHOENIX AIR JACK (In Stock)
Our new light weight, portable, Co2 operated jack is made specifically to carry on UTV's and other lightweight off road vehicles. It utilizes 20-25 gram Co2 canisters to operate and comes with 4 cartridges. It is supplied with a bag to carry the jack and accessories. Brushed Stainless Steel construction makes it look great and will last many many years.
Specifications:
100% stainless steel. Over 2' of adjustable lift height. Co2 Regulator controls flow and lift speed in both lift and release. Can be mounted to roll cage with quick release fire extinguisher style mount. Weighs 5.6 LBS.
Accessories include:
Large base for use in soft dirt or sand. 4" round top. Velcro Holster to hold regulator and Co2 Cartridges. Quick release roll cage mount.
PM or order online.
pro eagle
Will it lift a long traveled rzr? Didn't see any heights listed. I have their 3 ton and their products rock!!
craigstumph
craigstumph
Discussion Starter #9
craigstumph
Discussion Starter #10
Pro Eagle told me 14" to 19". I asked them to send me the specs because it did not seem correct. More coming when I get the spec sheet.
Any updates? Just really curious what the closed dimensions are. And, I'd love to know the diameter of the base. Thanks!
craigstumph
Discussion Starter #12
Specs:
  • Length is 13" collapsed
  • Extended is 19" + 6" Stroke = 24"
  • Stroke is 6"
  • Weight in carry case with all components is 9 lbs
  • Capacity is 2000 lbs
  • Base is 4.25"
Specs:
  • Stroke is 6"
  • Base is 4.25"
Amazing. Thank you!
craigstumph
Discussion Starter #16
Put one in your own sock for Christmas!
craigstumph
Discussion Starter #17
Specs:
Stroke is 6"
Lifting capacity is 2000 lbs
1 - 20 of 57 Posts
