Primary clutch slow to open
5.8K views 10 replies 5 participants last post by  rijoh2000
Hey guys long time reader new poster here. Hope I’m in the right category. I have a 2014 rzr800 and I rebuilt the primary clutch with a new bearing and washers. I have done many clutches and can’t for the life of me figure this out. The machine has about 1400 miles on it.
i installed the clutch after the rebuild and it seemed to work fine and shift good. After a while it would grind when shifting gears. I thought it was maybe an alignment issue but wasn’t. The sheaves on the primary are very slow to open up and disengage the belt after revving the engine. This happens with or without the belt installed.I’ve been through the clutches a couple times and can’t find anything wrong.
the sheaves moves nicely on the shaft with the spring removed and with the spring installed I can compress the sheaves to fully closed by hand.
My rollers don’t have flat spots and my weights seems in as good a shape as any. Spring measurements were in spec with the service manual.
i might add that I did the clutch work after a complete engine removal and rebuild.
Any suggestions would be great before I start throwing money at more parts…
If you can compress the clutch fully closed by hand that makes me think the spring is weak.
  • Like
Reactions: Trailwolverine
Can you check the towers to see if they are spaced wider at the top or bottom? Did you replace the buttons? If they are too tight it might affect opening and closing. If they are too loose they could slide at an angle and bind.
A random thing I did once happened when I was torqueing down the spider. It goes against the spacer that sits on a shelf on the primary shaft. When I torqued it, it spread itself out and made it difficult to open/close. See if it measures the same diameter as the bearing. It is part number 18 in the diagram below.
BTW... Parts #4 and #1 are the bushings and they are lined with teflon.
Another thought would be the spider has backed off.
  • Like
Reactions: rijoh2000
The primary spring could be a problem and causing the grinding going into gear. If the primary spring is weak, the flyweights could be moving the sheave prematurely even at @ idle. I would imagine though if this were the case his engagement RPM would have to be around 1200-1300 rpm. He also wouldn't be able to rev very high as the flyweights would open too quickly before it reached peak rpm. Something is causing the primary not to release the belt at idle. Maybe it's the belt itself.
True, but something tells me, we may never find out what his issue is/was. He hasn't been here since April, so I doubt he'll be back until he wants to know how big of tires he can fit without a lift!!! :ROFLMAO:
  • Haha
