2019 Rzr 1000s
No rider poly window front, rear and roof
Cargo box 25-30 lbs
Should it sit level ? High in front or rear ?
Walker Evan shocks owners manual says 6.1” front and 3.31” rear preload what are people running
Adjust until you get the desired ride height. On an S with stock tires that is about 14-15 inches of ground clearance. I usually run the rear about an inch lower than the front. Measure with it fully loaded.
1. Measure the ground clearance (gc).
2. Jack up the machine, full droop, adjust the pre-load ring. Keeping the side to side adjustment equal.
3. Lower the machine and drive around. You must drive to settle the suspension.
4. Measure GC again, front and rear.
5. Repeat until you get desired ride height.
Make sure the shock body's are very clean before adjusting.
I know how to do it and have measured GC. Try to see what people’s measurements on shocks where. Mine is sitting a lot higher in rear. Thank you though. I also run 30” tires with 9lbs in them
