Ok, so I am hooking up my winch and my radio. I do not want to hook both directly to the battery, so I am looking for a relay and a somewhat waterproof fuse block to hook them to a switched source somewhere. The problem I am having is where to run the power wire from the relay to? Again, really not wanting to run directly to the battery, so where is your recommendation. I was looking at maybe running it to the solenoid? Or do you think it would hurt to go directly to the battery? Also, 30 Amps should be a big enough relay huh?
2009 RzR 50" btw.
2009 RzR 50" btw.
