Post Your "GREAT" Clutch Setup Here!
30868 Views 31 Replies 23 Participants Last post by  Highrider
Post Your Clutch Setup! If you are running a good clutch setup that WORKS! post it here: Please tell us, Year and Model of RZR, Tire Size and Model, Engine Mods, Engagement RPM, Top Speed and RPM, Elevation where you ride, Above 3K or Below, Please list each component if you know or list the Brand and Part # of the "Kit" you are running. Some of these setups my work for you if your RZR is setup close to a Posters Listed Setup, or it May not. This List is simply to share info or provide a starting point for clutch mods. Please only post clutch setups in this topic, other posts or remarks will be removed.
:Using Info provided here is done at your Own risk:
Please Copy the Template below and post your info:
My Elevation: Above 3K or Below 3K
Year and Model:
Tire Size & Model:
Motor Mods:
Engagement RPM:
Top Speed & RPM:
My Setup, Brand or Company:
Primary Weights listed in Grams:
My Primary Spring. Color: Weight#
My Secondary Clutch: Stock: Other:
Secondary Clutch Spring Color: Weight#
Hellix#
Belt: Stock: Other:
I have Engine Braking System, (EBS): Yes: No:
My Opinion on how this setup compares to Stock:
See less See more
1 - 20 of 32 Posts
My Elevation: Above 3K or Below 3K. Below
Year and Model: 2010 RZR S
Tire Size & Model: 27" ITP Mudlite XTR
Motor Mods: None
Engagement RPM: 1340
Top Speed & RPM: 60 mph, RPM? but not hitting the Limiter
My Setup, Brand or Company: Running Stock 09 S Setup
Primary Weights listed in Grams: 74 grams
My Primary Spring. Color: red with white mark, Weight# 48-240
My Secondary Clutch: Stock: Other: 09 Stock S Team Secondary.
Secondary Clutch Spring Color: Red Weight# 105-160
Helix# Stock S 66-56-33 but with added EBS Notch.
Belt: Stock: Other: Stock 2010, #321133
I have Engine Braking System, (EBS): Yes: I added Engine Barking system using a 09 S hellix with EBS notch bought from Team industries (79.00) This can only be added to a 2010 if you purchase a 09 style secondary clutch.
I now have a harder hitting clutch that pulls harder and i also now have Engine Braking which no 2010 rzr has standard.
See less See more
My Elevation: Below 3K (sea level for the most part)
Year and Model: 2009 RZR-S
Tire Size & Model: 25x10x12 scat tracks and buffs on Douglas reds and stock Bighorns on stock rims.
Motor Mods: MCX stage 1 turbo kit (80rwhp prox)
Engagement RPM: never looked
Top Speed & RPM: 63mph & stock rev limiter
My Setup, Brand or Company: MCX adjustable weights, EPI belt and springs
Primary Weights listed in Grams: 91 grams (65g arm, 14g base, 6g mid, 6g tip)
My Primary Spring. Color: Weight# Red EPI
My Secondary Clutch: Stock: Other: stock Team Roller
Secondary Clutch Spring Color: Weight# Lime Green EPI
Hellix# stock
Belt: Stock: Other: EPI severe duty
I have Engine Braking System, (EBS): Yes: No: I replaced the one way bearing in the primary with a two way.
My Opinion on how this setup compares to Stock: Stock won't work with a turbo.
See less See more
My Elevation: Above 3K or Below 3K …… Below 3k
Year and Model:…………………………………….2009
Tire Size & Model:…………………… 25x10x12 8 paddle skats rear and buffs front
Motor Mods:…………………………….. 900cc Big Bore MCX Turbo 11psi Boost
Engagement RPM:…………………………2100 RPM
Top Speed & RPM:………………………..7800 RPM 75 MPH
My Setup, Brand or Company:……….DDP Adjustable The base weight is 73g …. I added
3.5g base
8.5g mid
6g tip
For a total of 91g
Primary Weights listed in Grams: ……91g
My Primary Spring. Color: ….Red with green and black markings, I don’t know the weight.
My Secondary Clutch: Stock:….Stock
Secondary Clutch Spring Color:....... Lime Green with silver marking
Helix# …………………………………………………? I will need to look
Belt:………………………………..EPI Severe Duty
I have Engine Braking System, (EBS)……… No
My Opinion on how this setup compares to Stock: No comparison ……apples and oranges
See less See more
Come on guys, list your clutch setup that works for you so others can benefit. If you dont know the # number of your springs, list the color and i can most likely tell you.
My Elevation: Above 3K or Below 3K=below
Year and Model:--2008 gen 1 rzr
Tire Size & Model: 26 bighorns
Motor Mods:none- just hotride4u ecu
Engagement RPM: 2450
Top Speed & RPM: 58== 6850
My Setup, Brand or Company:dirty dawg all the way
Primary Weights listed in Grams: 54g weight
12g on heel
3g in the mid
2g on the tp
My Primary Spring. Color: Weight#red with yellow and silver
My Secondary Clutch: Stock: Other:ddp helix
Secondary Clutch Spring Color: Weight#lime spring
Hellix# have to look
Belt: Stock: Other: polaris
I have Engine Braking System, (EBS): Yes: No:yes
it ripps off the line a has a awsome pull up to about 50< going to try adding more weight in the middle
See less See more
12g on heel
3g in the mid
2g on the tp
What is your total gram weight, 71? I ask cause the adjustable kit DD sends out most times has a initial weight of 52grams before adding bolts and washers. That would make youre's 69.
just want to keep things clarified for those who might try a set up. thanks for sharing:ride:
My Elevation: Sea level on up.
Year and Model: 09 RZR Standard
Tire Size & Model: Stock front, 26" Sand Star Rears
Motor Mods: Intake, The rest is stock.
Engagement RPM: Around 1800RPM
Top Speed & RPM: 65 @ 6400RPM
My Setup, Brand or Company: Dirty Dawg Performance Complete 09 Setup: Adjustable weights, upgraded springs, new secondary and helix.
Weighed them with a gram scale that is accurate to the tenth.
Base Weight = 51.4g
Bottom Weight = 12.6g
Middle Weight = 3.6g
Tip Weight = 3.9g
Total Weight = 71.5
My Primary Spring. Color: Red
My Secondary Clutch: Team Roller
Secondary Clutch Spring Color: Never saw, its what Dale sends. Looks to be black
Hellix# Never saw, its what Dale sends with his 09 complete kit. Anyone?
Belt: EPI, stock backup
I have Engine Braking System, (EBS): My rig definatly engine brakes so I guess so
It upped the initial target RPM from 55-5600RPM to 6000RPM. Better engine braking over the stock 09. Seems to upshift and downshifter a lot harder.
See less See more
Year and Model: 2009 Standard RZR
Tire Size & Model: 26" Maxxis Zillas on 12" wheels
Motor Mods: Muzzy Dual Exhaust, K&N Filter (snorkeled), Fuel Controller
Engagement RPM: 1950-2000 RPMs
Top Speed & RPM: 64 MPH/stock rev limiter
My Setup, Brand or Company: Dalton Industries DUV-P8RZ
Primary Weights listed in Grams: 67 base, .85g rivet at tip, 1.2 + .6g threaded inserts= 69.65g total
My Primary Spring. Color: Black w/ Orange Stripe (DPPS-B/O)
Secondary Clutch Spring Color: Stock
Helix# Stock
Belt: Stock
My Opinion on how this setup compares to Stock: Launches MUCH harder (leaves 30ft. on dry pavement), jumps to 6000 RPMs & pulls better all the way up to top speed, no top end loss, couldn't be happier!!
See less See more
Base Weight = 51.4g
Tip Weight = 3.9g
Total Weight = 71.5
primary spring will have a second color mark, example red w/white mark is stock S, DDP mostly ships his kits with a RED w/green and black marks and a lime green w/silver mark secondary.
To be determined soon:devil3: then ill post results with weights and springs!!! I just have to wait for Fox to revalve my shocks :rollfinger:
See less See more
My Elevation: Sea level up to 4K
Year and Model: 2008
Tire Size & Model: 25x10x12 8 paddle Skats rear or 25.5x13x12 Doonz 8 paddles /buffs front
Motor Mods: MCX Turbo 860 BB kit
Engagement RPM: 2200
Top Speed & RPM: 62 MPH @ 6500 RPM
My Setup, Brand or Company: MCX ( STM ) weight, DDP springs
Primary Weights listed in Grams: Total 95 grams
base 68 grams
bottom 14 grams ( 2 tungsten washer )
middle 6 grams
tip 6 grams
My Primary Spring. Color: DDP Red/Purple Weight#45/143
Secondary Clutch Spring Color: DDP Green/Silver Weight#125/190
Hellix# DDP cut
Belt: Stock: Other: EPI heavy duty
I have Engine Braking System, (EBS) No:
My Opinion on how this setup compares to Stock : Hard to compare to stock with so many engine upgrades.
See less See more
Year and Model: 2009 RZR-s
Tire Size & Model: Stock Big Horns
Motor Mods: Full HMF Exhaust, UMP Intake, Dynatek Ignition & Power Commander
Engagement RPM: about 2150rpm
Top Speed & RPM: 64.5 @ 6600rpm
My Setup, Brand or Company: EPI Kit
Primary Weights listed in Grams: 74grams
My Primary Spring. Color: Weight# White Spring
My Secondary Clutch: Stock: Other: EPI
Secondary Clutch Spring Color: Weight# Green Spring
Hellix# EPI balanced
Belt: Stock: Other: EPI Heavy Duty Belt
I have Engine Braking System, (EBS): Yes: No: Don't know
I think this setup is getting closer.... pulls hard and quick to 6100rpm.... then takes a while and it climbs to 6600rpm. Top speed of 64.5mph at 6600 rpm. I'd like the top rpm's to be around 6400rpm and a top speed above 65mph.
See less See more
My Elevation Below 3K
Year and Model:2008 RZR
Tire Size & Model: 25 inch Maxxis 4 speeds
Motor Mods:840 all motor
Engagement RPM:approx 3300
Top Speed & RPM:roughly 78 @8000 RPM (clutched at 7400 rpms)
My Setup, Brand or Company:Team Industries Parts
Primary Weights listed in Grams:72 gram fixed weights
My Primary Spring. Color: Weight#140/290
Secondary Clutch Spring Color: Weight#Pink EPI
Hellix# HPD
Belt:Dayco HPX
See less See more
Tire Size & Model: Maxxis RAZR Speed 4 radials 26x11x12
Motor Mods: FMF exhaust, Dynatek CDI, holz intake vent with ump
Engagement RPM: 1700
Top Speed & RPM: 65 at 6800
My Setup: DDP
Primary Weights listed in Grams: 74 grams, 52g arm 10g heel, 6g mid, 6g tip
My Primary Spring. Color: Red, black and green Weight#
Secondary Clutch Spring Color: lime green and with silver Weight# 105-165
Hellix# the one that come with the Dirty Dawg kit.
Works well on trails, have not try it in the dunes. quick to 6100 and pulls hard to top end.
Belt: Stock: Other:
See less See more
My Setup: DDP
Belt: Stock: Other:
great! but one correction, the lime green with silver secondary spring is rated at 125-190, the 105-165 is the stock 09 S red spring rating.
My Elevation: Above 3K or Below 3K Below
Year and Model: 2008 Std.
Tire Size & Model: 25 X 10-12 Skat Extreme 8 paddle rears, stock front
Motor Mods: UMP intake
Top Speed & RPM: 62 mph approx. 6200 rpm
Primary Weights listed in Grams: 52 g arm, 9 g heel, 9 g mid, 10 g tip, 80 g total
My Primary Spring. Color: Weight# Red with green and black stripes
My Secondary Clutch: Stock: Other: Stock
Secondary Clutch Spring Color: Weight# Lime green with silver
Hellix# DDP cut with EBS notch
My Opinion on how this setup compares to Stock: Much improved holeshot, real snappy down low for the trails, climbs dunes much better due to better backshifting.
I'm supposed to be on vacation....WTF am I doing on here?...Does this mean I have a problem?....LMAO :rofl3:
See less See more
Hey Jeff, is this the current set-up I`m getting?
1 - 20 of 32 Posts
