A recent issue has surfaced. A buddy of mine and I went out on a short run the other day. We are both big guys so the RZR was loaded down pretty well.
Midway through the ride, I noticed a fairly loud popping sound coming form the rear left side when we were articulating over some of the terrain. It wasn't anything terribly difficult. Then after a few more turns, the sound started coming from the right side too!
The sound is not continuous - just a single POP when the chassis is flexed slightly. I've seen mention about brake calipers loose, so I may look at that, but this situation doesn't sound like what other people are describing.
Ever since then, whenever we are slowly creeping over uneven terrain and flexing the suspension, the popping will be persistent - first one side, then perhaps the other depending on the angles.
I'm not an expert with the RZR's mechanical functionality, but this sound is very similar to what my old truck sounded when a ball joint failed and was popping in and out of place.
Any suggestions?
Any suggestions?
