1 - 3 of 3 Posts
Southern Indiana Hoosier
Popping sounds coming from u-joints in the steering , or in the steering bearing. Only when the steering wheel is turning. Anybody had this problem? Whats the cure?:redrzr: Its practically a new machine....Noise is clearly next to the steering wheel. Will my extended warranty cover this?
bet its the bushings on your front swarbar , makes a ratling sound in the front end cheap fix, look at the top of the swaybar on both sides see if its the same.
Machine is nearly new... I'll check that... acts like loose bearing in steering wheel or first u joint next to wheel. thanks
1 - 3 of 3 Posts
