1 - 3 of 3 Posts
craigstumph
2019 ultra low geared Turbo S 4
4% lower gearing for your RZR Turbo/Turbo S/RS1
Use this belt with the shims provided to get lower gears for your RZR
Replace the stock driven (secondary clutch) shim with the shims we provide (they are under the bolt). Install the belt and your machine is lower geared. This kit raises the belt in the driven clutch by approximately 3/16". This is effectively lowers your gear ratio in the clutch.
Instructions: Do not attempt this procedure if you are not qualified to change your own belt. The provided shims may need to be adjusted if your RZR does not shift correctly. Two shims are recommended. Use 3 or a combination of the provided shims and the stock shim if you experience hard shifting. Your goal is to find the sweet spot where the driven clutch does not spin or has very little movement at idle.
Polaris RZR Turbo Low Geared Belt G-Force™ Redline™ CVT Belt by Gates – Pro UTV Parts
This is awesome! I will be ordering and installing this on a few machines once I get back from a long vacation. Can’t wait to test this out.
1 - 3 of 3 Posts
