1 - 6 of 6 Posts
Anyone have the 14" polsris wrec wheels. Just put a set on and it makes the rear a couple inches a side wider than the front. Is this ok. I got them as a kit from the local dealer.
I am looking into this as well. Not a lot of pics of that wheel. I am trying to find info on a review or the warranty terms of it.
Like the look and the way it handles. I switch between them and a set of raceline beadlocks. I wish the beadlocks had the offset and width the Polaris wheels do.
If they are the Wrec 14" wheels, they are a 14x7 with a 4+3 offset.
You assume that. He probably has the 4+4 offset, that is why the rear is wider than the front and stock. Stock rear wheel is a 8 inch wheel with a 5+3 offset. Unless you specifically request a 7 inch 4+3 offset rear wheel, dealer will give you the 8 inch for the rears as Polaris intended.
I wasn`t assuming anything, but your right, the front WREC wheel is a 4+3 and the rear is a 4+4.
1 - 6 of 6 Posts
