1 - 3 of 3 Posts
Anyone know if the plastic seat bases on the Jagged X front seats are the same seat bases as a standard 900xp? I'm considering cutting the driver's side a bit so it clears an air compressor I'm installing, but just in case it might compromise the integrity of the seat base, I'll need to be able to round up another without looking for the proverbial needle in the haystack of Jagged X (1500 units total) parts.
Thank you for replies.
I had to replace the drivers side base. The drivers side is adjustable so it is a bit different than a standard 90xp base. I bought a 900xp base and had to make a few alterations to get the adjusting hardware to fit but it was easy using the original base as a template.
Thank you Garster4x4. I'm hoping the seat base doesn't weaken by cutting it, but we shall see. I have another thread on this forum with pictures showing the air compressor conflict with the seat base. Thanks again.
1 - 3 of 3 Posts
